Indicates that WC and RPT bit combination in the received checkpoint message is erroneous. As per PIM RFC if WC bit is set then RPT bit must be set. If this is not the case then the above message is logged.
This is a rare internal condition needing technical assistance. Contact technical support with output from following commands: 1. show pim cache detail 2. show pim
Error
Erroneous bit combination in checkpoint message flags %flags%
| Name | Type |
| src | IPaddrN |
| grp | IPaddrN |
| flags | uInt32 |
